When I start the dishwasher, it begins the initial water fill, then stops. After that all I hear is the motor running. Neither top nor bottom sprayer is working.
Remove the lower spray arm and the top parts from the pump. Replace the wash motor seal kit (#9 on the break down diagram). - The part number for the wash motor seal kit is AP3853425 Gene.
