requestear
#1 Posted : Sunday, October 19, 2008 10:17:47 AM(UTC)
requestear
spin cycle not working.Clothes remain wet, does not appear to be spinning.washing machine sounds like it is working.
#2 Posted : Monday, October 20, 2008 9:12:30 AM(UTC)
Remove the front panel. Check the belt and hoses to and from the pump for a clog. Remove the tub cover (#13 on the break down diagram) and, using a flashlight, check for a foreign objects between the inner and outer tubs.
Here are the break down diagrams for the Maytag washer Model MAV7600AWW
requestear (Washer Repair)
by requestear 10/19/2008 10:24:55 AM(UTC)
