I have a moffat electric stove (Canada). The clock will only come on if a burner or the oven is turned on. When I turn a burner on it does not warm up. Any suggestions?
Thanks:confused:
Replace BOTH house fuses or reset the circut breakers, If this does not work, you have a burned wire.:)
