AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
is there more the one screw to remove contrl cover inner l side
Inside ref back left side is temp and baffle for freezer is there more then one screw holding it on when both knobs are removed don't want to break it
Originally Posted by: dbfarah  Inside ref back left side is temp and baffle for freezer is there more then one screw holding it on when both knobs are removed don't want to break it DB, I think this will get you where you want to be. Refrigerator Temperature Control
1. Remove control knobs (nonelectronic models). 2. Loosen bracket on bottom left of cover to allow cover to be rotated forward. 3. Pull bottom of cover out until it unsnaps. Continue tilting cover out until top tabs release and remove cover. 4. Remove insulation over top of damper. 5. Remove styrofoam filler piece from control body exposing two mounting screws. 6. Remove mounting screws to remove control.
Good Luck, :cool: :cool: :cool:
