My granddaughter fell on the door, (it was down)...it started leaking and I had a repairman fix it (after he fixed it, the door was very hard to close) but it has started leaking again...do you think I could change out the hinges and take care of it? Thank you, Kim
Originally Posted by: mommakimmie  My granddaughter fell on the door, (it was down)...it started leaking and I had a repairman fix it (after he fixed it, the door was very hard to close) but it has started leaking again...do you think I could change out the hinges and take care of it? Thank you, Kim Kim, Under the circumstances, Yes, A set of new hinges will probably help, Were it me, I would also check the inner door liner, where the hinges attach, to see if it was stressed out of shape. And the frame of the tub, in the hinge pivot pins area, for also being bent. Chances are you'll be able to compensate for bent parts and not really need a new dishwasher. Good Luck, :) :) :)
