monkeypincher
#1 Posted : Friday, October 17, 2008 10:43:20 PM(UTC)
monkeypincher
The motor coupling between the motor and gearbox has grenaded. How do you get the motor off the gear box to replace it? The two screw heads are inside the motor housing so it looks like you have to take the motor apart to get to them.
Also, what weight gear oil does the gear box take? And how much? Do you just fill it to the top of the case and then put the cover on? (yeah, I took the stupid thing apart before I found the motor coupling :rolleyes: )
Also, I notice the Brake Cam Driver is missing a little tab shown indicated below. What does it do?
monkeypincher attached the following image(s):
v2k04
#2 Posted : Saturday, October 18, 2008 8:09:38 AM(UTC)
v2k04
Replace the clutch it sould come packaged with the spin tube cam thats broken also replace the coupler
