We have a very low hour Jenn Air 27" Double Oven. Worked PErfectly last fall and was reinstalled this fall and apon connecting power, the display is flashing JJJJ jjjj jjjj and 067 0000 0000. If you push any of the controls on the top over, nothing happens. If you push any on the controls on the bottom oven, you hear a relay click. Any sujjections please.
Check the power source to see if you have 240VAC at the outlet. If it was rewired, or moved, check to make sure you have the correct polarity.
Originally Posted by: magician59  Check the power source to see if you have 240VAC at the outlet. If it was rewired, or moved, check to make sure you have the correct polarity.[/qu
The Out let check out good and working properly. Thanks
Originally Posted by: JZ2010  Originally Posted by: magician59  Check the power source to see if you have 240VAC at the outlet. If it was rewired, or moved, check to make sure you have the correct polarity.[/qu
The Out let check out good and working properly. Thanks After having power to the unit for about 4 hours, the unit is beeping fast and displaying FO on the display, the clock is now working and keeping time. Thanks
