Hello, I have a whirlpool quiet partner I , model number DU915PWKS0 , that hums only but nothing else happens, no water , no cycling. it works great before. I remember one day turning the water supply nub off temporarily and i did turn it back open later, so i am not sure if somebody did try to run it for a long time without the water while i am away. Could this have damaged or burn something in there? pleaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaas help. Of course my wife just wanted me to replace the whole thing with a new one. I save $300 last year by just replacing a switch ($12.00) , in my microwave with help on this site. Thank you soooooooooooooooooo much. Ish.
Originally Posted by: ish2008  Hello, I have a whirlpool quiet partner I , model number DU915PWKS0 , that hums only but nothing else happens, no water , no cycling. it works great before. I remember one day turning the water supply nub off temporarily and i did turn it back open later, so i am not sure if somebody did try to run it for a long time without the water while i am away. Could this have damaged or burn something in there? pleaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaas help. Of course my wife just wanted me to replace the whole thing with a new one. I save $300 last year by just replacing a switch ($12.00) , in my microwave with help on this site. Thank you soooooooooooooooooo much. Ish. ISH, That's where I would start, the fill valve Part number: AP3037492
Based on your information, You may have burnt out the fill valve, but most likely, you have a clogged fill valve screen filter, due to debris in the pipe that was built up in the pipe. Good Luck, :) :) :)
thanks Joe, i will go and check the pipes right away.
Originally Posted by: ish2008  thanks Joe, i will go and check the pipes right away. ISH, Go to all the faucets and remove the areator screens from the spout(s) and run the water(both hot and cold) for a couple of minutes, or until the water is clear. Especially the kitchen faucet, then replace the fill valve. :cool: :cool: :cool:
