Dan S.
#1 Posted : Friday, October 17, 2008 8:46:56 AM(UTC)
Dan S.
My dryer heats fine on medium heat, but on high heat it doesn't heat at all. The timer works fine, the motor works fine, just the high heat doesn't heat at all. Any ideas
libertyappl
#2 Posted : Friday, October 17, 2008 8:57:56 AM(UTC)
libertyappl
Test the thermostats on the back of the unit for continuity, behind the rear panel. I would say one of those is out not allowing the higher temp.
Nat
