I have a Kenmore Electric range. The clock and the oven no longer work, but the stove top elements heat just fine. In several threads, I see the probably culpret is the clock/timer controller, but in all the cases I have read, only they oven is not working and clock is working. As I said, in my case, the clock is not working also. Would the clock/timer controller still be the culpret?
My tenent just called me to say the clock and oven are working again, just out of the blue. The range is a Kenmore model #911.9544590. Is there some type of auto reset that would trip then reset after a couple of days?
