crz4cats
#1 Posted : Tuesday, October 12, 2010 12:54:30 PM(UTC)
crz4cats
Dryer worked fine yesterday. This morning it would not start but the light comes on when the door is opened and shuts off when the door is closed. I have unplugged it, reset the breaker and even removed the back panel and made sure the cord looked good and pushed all the connections in. After I pushed in the connections it started back up. I then stopped it to make sure it was heating, which it was, and then tried to restart it but it would not start. Motor works fine, belt is not broken, maybe something with the start switch or a loose connection???? I cannot figure out how to get the rest of the back off to follow the wires. Please let me know if you can help. The model number is dbsr463eg6ww.
sidfink43
#2 Posted : Friday, October 15, 2010 10:21:29 AM(UTC)
sidfink43
The back does not come off these models, you access everything from the front. This is done by removing the screws inside the door jam that hold the top on and taking the top off.
First I would try replacing the start switch. You may also have a problem with the connection block that you cannot see, so check it again.
GE Dryer will not start (Dryer Repair)
by Robster 9/27/2010 7:32:19 PM(UTC)
by Lubahn09 3/25/2009 6:34:14 AM(UTC)
