Potsnpans
#1 Posted : Tuesday, October 12, 2010 10:03:45 AM(UTC)
Potsnpans
I have a 2 year old Whilpool GU3600XTSB2 that has a flashing power scrub light. It won't start and if I try to push other cycle buttons like the 'normal' or 'adaptive wash' they start flashing also. Pushing the cancel button does nothing. If I kill the power and then turn it back on the power scrub light starts flashing again with alternating 2 slow flashes with quick flashes. Any ideas as to what is wrong? And how to fix it.
Joe / APP Team
#2 Posted : Tuesday, October 12, 2010 11:06:15 AM(UTC)
Joe / APP Team
Potsnpans,
Your description indicates you have a malfunctioning touchpad,or loose touchpad tail assembly or bad control board in the control panel,
You may want to try and program the control test program(per the technical data sheet, attached to the backside of the kick plate panel on the front of the machine), to varify that.
But I'm pretty sure you'll need the touchpad assembly,
Part number: AP3951368
UserPostedImage
Good Luck,
