a FEW WEEKS AGO MY SON LEFT THE FREEZER DOOR OPEN WHICH CAUSED AN ICE BUILD UP AND THE FREEZER TO UNTHAW....... i CALLED A TECH WHO TOLD ME THAT IT WOULD CORRECT ITSELF AFTER A FEW HORS, WHICH IT DID....ALL WAS FINE FOR A FEW WEEKS AND THEN THE FREEZER THAWED AGAIN....DOOR CLOSED THIS TIME BUT THE FRIDGE WAS COLD AS USUAL.
I TURNED UP THE TEMP SETTING FOR THE FREEZER TO 9 AND IT STARTED COOLING.......AFTER IT FROZE I TURNED IT BACK DOWN AND ALL WAS GOOD FOR A FEW MORE WEEKS.....TODAY NOTHING IS COOLING.....THE FAN IN THE FREEZER AND UNDERNEATH IN THE BACK ARE RUNNING BUT NO COOLING......i CLEANED ALL THE DUST ETC.....FROM BEJIND AND UNDERNEATH A MONTH AGO AND IT STILL LOOKS GOOD....
I CANT GET A REPAIR GUT TILL' MONDAY AND THEY WILL PROBABLY CLIP ME FOR A FEW HUNDRED $$ SO ANY HELP TILL' THEN WOULD BE GREATLY APPRECIATED...
THANKS BOB
