Whirlpool Side by Side Ice maker: Stop making ice one day. Unit was slow to make ice then completely stopped. Water in the tray, line is not frozen. would make one or two cycles then stopped. took unit out thawed it out, put it back in, worked fines for about 10 - 12 cycles and now stopped? What would cause this to operate on and off? Also i did notice the coating on the tray peeling a little? Thanks,
:confused: Originally Posted by: Euroman  Whirlpool Side by Side Ice maker: Stop making ice one day. Unit was slow to make ice the completely stopped. Water in the tray, line is not frozen. would make one or two cycles thane stop. took unit out thawed it out, put it back in, worked fines for about 10 - 12 cycles and now stopped? What would cause this to operate on and off? Also i did notice the coating on the tray peeling a little? Thanks,
