CLEANMACH
#1 Posted : Monday, October 11, 2010 12:24:19 PM(UTC)
CLEANMACH
This Unit Was Replaced Over 1 Yr Ago So This Is Only Just Over A Yr Old. Tray Fills But Will Not Empty. Sounds Like It Is Tryi Ng And Some Thing Is Slipping. Makes A Thumping Noise. Have Had It All Apart But See Nothing Broke. Don't Know What Part Inside Needs To Be Replaced. THIS UNIT IS IN A GE PROFILE PFSS6PKWASS
#2 Posted : Monday, October 11, 2010 4:22:08 PM(UTC)
Measure the temperature in the freezer. It suppose to be bellow 10°F.
If the temperature is fine, verify the operation of the Ice maker sensor (#35 on the diagram) in the tray. Normally the unit harvests when the sensor reads approximately 1.5°F for 5 minutes. The sensor should read about 3.7VDC at the main board connector when the cube temperature is 1.5°F. After the fill, the sensor will read water temp, 1.5 to 2.2VDC. Remember, using frame ground might produce inaccurate values; instead use the DC ground on the PC board. If this value is incorrect the sensor is suspected to be defective.
- The sensor Part number: AP4344976
- The ice maker Part number: AP4321616
