DARINNORTH
#1 Posted : 14 years ago
DARINNORTH
My GE Water and ice dispenser work fine; however, after filling a glass of water, the water dispenser takes a solid 30 seconds to a minute to stop the water. BAsically the water stops flowing slowly, eventually going into a steady drip, then stops, usually overflowing our glasses and creating a water spill. It used to stop immediately when the switch was released.
I've read some posts and should add that I have not replaced the filter since I've owned it, at least three years now. I will be replacing the filter, but thought I may be able to purchase another part at the same time to fix this water issue. Can anyone recommend the part I should change, and its location? Thanks for your help!
