dadd
#1 Posted : Wednesday, October 15, 2008 6:10:02 PM(UTC)
dadd
does anyone have a tech manual for this older model? tested valve 1000ohms and tested drain motor 16 ohms, i think the timer is not working as water will not load or drain.
#2 Posted : Thursday, October 16, 2008 2:41:22 PM(UTC)
Looks like the problem is a bad water valve - 1000 Ohms is too much. Normally it suppose to be about 20 Ohms to 50 Ohms.
- The part number for the water valve is AP2802210
Here are the break down diagrams for the Bosch dishwasher Model SMU3032 UC/14 (FD 7507-7902)
P.S.It is very hard to find any technical documentation for a such old model.
dadd
#3 Posted : Thursday, October 16, 2008 4:25:02 PM(UTC)
dadd
thanks Gene,
the values for water valves are normally 1000ohms where do you get your value from. there is no voltage going across the water valve either?
#4 Posted : Friday, October 17, 2008 2:41:13 PM(UTC)
Sorry, my mistake - looked at wrong place. It suppose to be about 1 KOhms.
Did you check the float (on the left side of the dishwasher)?
You probably can test the timer, using the tech wiring diagram.
P.S. You also can use the troubleshooting, attached to this reply.
File Attachment(s):
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD 12/7/2023 2:38:23 PM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
Bosch Dishwasher Model SHE3AR56UC/07 (Dishwasher Repair)
by EDK1747 8/30/2023 7:42:58 AM(UTC)
Bosch Dishwasher SHE3AR56UC/07 (Dishwasher Repair)
by Guest 8/27/2023 11:27:21 AM(UTC)
Bosch Dishwasher skips to "clean" even after part replacement (Dishwasher Repair)
by Guest 6/20/2023 5:17:19 PM(UTC)
Bosch dishwasher SHX65T55UC/07 not dispensing soap unless in "Express" mode (Dishwasher Repair)
by callussun 4/19/2023 9:46:00 PM(UTC)
Bosch dishwasher shem3ay 55n/25 (Dishwasher Repair)
by Guest 3/23/2023 5:18:20 AM(UTC)
Bosch dishwasher only drains on reset and specific cycle (Dishwasher Repair)
by vusedad 10/18/2022 8:54:46 AM(UTC)
Bosch dishwasher model SMV41D10EU/48 Not working (Dishwasher Repair)
by adriandlb 10/7/2022 12:18:47 AM(UTC)
Bosch Dishwasher SHX68T55UC/02 Leak Identified: How to Fix? (Dishwasher Repair)
by jonneytaee 8/31/2022 4:48:51 AM(UTC)
Bosch Dishwasher Model SHPM65Z56N (Dishwasher Repair)
by Guest 7/8/2022 9:00:03 AM(UTC)
