i can here the limt switch clicking and there is a humming sound comming from the washer but it will not start the wash cycle i have tried the the rinse cycle not change what do i need to check?
Check the lid switch and the coupler. I hope you are charging them fairly. Either that or you seem to have a lot of appliances. Nat
when you say coupler what do you mean and where is it located?
The coupler is between the motor & tranny. If it is broken the washer will not agitate or spin. Nat
it will drain only that's it :(
