I can't find a wiring diagram and I removed the two wires to the blower motor assembly (see 14). One is white and one brown. Does it matter which goes to which? There is an upper and lower contact. Thanks alcatrazp attached the following image(s):
Makes NO DIFFERENCE!!!!!!!! Thats an A.C. motor. The ONLY time it matters is when its D.C. voltage.:D
Thanks, it's running smoothly!
