the-jag-guy
#1 Posted : Wednesday, October 15, 2008 9:59:12 AM(UTC)
the-jag-guy
We've owned this refrigerator since new and recently it just stopped cooling. It's in our garage and everything defrosted in the freezer before a problem was noticed. Initially I could hear the compressor start relay engage and then click off (and no compressor running) and I have a feeling this may have gone on for several days. The compressor/condenser fan underneath, and the fan inside the freezer/refrigerator were running normally- just no cooling. I pulled off the relay and thermal overload units on the compressor and replaced them with new parts (the old relay had a some parts rattling around in it.
After replacing these parts per the instructions in the kit, the refrigerator ran for a few minutes and then stopped, and now even the fans aren't running. There was no excessive noise, no heating up of parts (compressor was still cool tot he touch) The lights inside the door work fine, and there is power coming into the unit.
Note- at the same time the refrigerator was running after the repair, I was removing the icemaker from the freezer (it was never pumbed in the garage). I loosened the screws, unplugged the electrical connector from the back, and removed the unit. Shortly afterward, the refrigerator stopped as described above. Could it be related to the icemaker? Plugging the icemaker back in had no effect.
I've tried several times to let it sit for 15-20 minutes and then plug it back in- no change. Lights only- no fans, no compressor, and no compressor start clicks.
Any thoughts? This has been a good unit for us.....
v2k04
#2 Posted : Wednesday, October 15, 2008 10:09:30 AM(UTC)
v2k04
It sounds like at the same time you were doing the repair it timed into a defrost cycle plug it in and let it sit for 45 minutes it should come on or you can manually advance the timer. Removing the icemaker has no effect. look underneath the control panel on the right rear corner you will see a hole in plastice and the timer advance knob which will have kinda 2 riges where you can place a flat screwdriver, and a small hole in center and turn it clockwise to turn on frig
the-jag-guy
#3 Posted : Wednesday, October 15, 2008 10:36:59 AM(UTC)
the-jag-guy
I think you were right. I had left it plugged in while I came inside to write this post, and when I went back out 30 min later, it was running normally. I'll keep an eye on it and see what happens.
After readying several of the posts I had a feeling it had something to do with the defrost cycle...
