flowboard
#1 Posted : Friday, September 21, 2007 11:14:46 AM(UTC)
flowboard
I recently re-tiled my kitchen floor and removed all appliances. After about two weeks of having everything back in and hooked up, the dishwasher started leaking out of what seems like the bottom right of the door. I was wondering if there was a drain that might be blocked but I'm guessing that the door may need to be tightened or re-aligned. Any guidance would be greatly appreciated!
#2 Posted : Wednesday, October 3, 2007 7:52:29 PM(UTC)
Hi flowboard
Has the dishwasher been leveled properly after re-installation?
If not it could cause the leak.
Also you can tight the door by adjusting the latch keeper. It's located on top of the door frame and has two screws which allow you to tighten the door.
Also inspect the door gasket for any damage or misalignment.
Good luck.
