Standing water at bottom of dishwasher will not drain. I cleaned out the drain, I blew out the hose still nothing any suggestions :confused:
First place to check is the drain pump, it's easily accessable by removing door panel and lower kickplate panel it will sit in front which can be removed it takes a little twistin and turning to get it out. put it in a cancel/drain and listen for the motor to come on or check voltage while in drain .however a Bosch will pump at the beginning of each cycle you can check voltage then
