REPP
#1 Posted : Monday, October 13, 2008 7:50:18 PM(UTC)
REPP
MAYTAG WASHER VERY NOISY SOUNDS LIKE GRINDING ON SPIN CYCLE CHECKED PUMP AND MOTOR BOTH SEEM FINE REMOVED FRONT AND RAN WASHER NOISE SEEMS TO BE FROM BOTOM OF TUB NOT SURE HOW TO REMOVE INNER AND OUTER TUB:confused:
#2 Posted : Tuesday, October 14, 2008 4:01:47 PM(UTC)
Lift the washer from the front. Remove the belt and check if the pump (on the right side) is rotating freely. If not then replace the pump.
- The part number for the pump is AP3447809
Here are the break down diagrams for the Maytag washer Model MAV6250AWW
washer reppair (Washer Repair)
by Peterbon 8/23/2014 10:42:17 AM(UTC)
