I have a whirlpool, that was given to me. I have washed and cleaned it really good, but the ice maker dont not produce ice. I get water coming out of the despencer but no ice. How do i go about checking it? I know the arm chuck is down to make ice, but still no ice. the water tray is not getting water to it. What to do and what to buy to fix it. Can anybody help me out. Email me at jwynn007@gmail.com please!!!!!!!!!!!
Jason, In order to provide most accurate advice we need the complete model number of the refrigerator. The Model Number Locator may help you to find it. Gene.
I have a whirlpool, and the Model # is ed2chqxoo7 and serial # su4145854 and i think i might know what it is know but cant be to sure. on the back of the frieg were the water comes in the are a blue/red filter looking thing and i am getting water to the despencer but like i said before no ice. So i took the lines off the red one which is the ice lines and there is no water going to it. on either end. Could that be the filter problem or electrical problem?
Jason, Sorry for the delay. Make sure the water feeding tube into the ice maker is not frozen. Locate the water inlet valve on the back of the refrigerator (#6 on the diagram). Swap the wires between the solenoids and press the water dispenser release lever for a few seconds. Check if there is water in the ice maker. If there is no water, replace the water inlet valve. If there is water, replace the ice maker. - The water inlet valve Part number: AP3890554
ok it wont let me whitch the wires cuz they are 2 different plugs. do you have personal email that i can write to you? But i have looked at the back and there is water going to it but just not coming out the red solenoids the one it goes up to the ice maker. can that just one go bad and not the other?
Originally Posted by: Jason Wynn  ok it wont let me whitch the wires cuz they are 2 different plugs. do you have personal email that i can write to you? But i have looked at the back and there is water going to it but just not coming out the red solenoids the one it goes up to the ice maker. can that just one go bad and not the other? Jason, Try to use some extension wires to connect the plugs. Gene.
are you checking to see it the plug has power?
i checked with a meter and i have 17V to the water plug and 10V to the ice maker plug. Whats the next step to do
