SLR
#1 Posted : Monday, October 13, 2008 6:08:40 PM(UTC)
SLR
Original problem was that when bake temp button pushed, oven begins to warm up (starts at 100 degrees) but after a few seconds oven turns off. Recommendation was to replace temp sensor which I did. Problem is still the same, except that if I repeat hitting the bake temp button before it turns off, I the oven evently gets to 105 temp and stays on until it reaches desired temp. At this point oven works fine and can set all timers and reset temp. When I finally turn off by hitting cancel, oven beeps a few times and a code appears on digital readout the code is F-1
Need assistance
paulr44
#2 Posted : Monday, October 13, 2008 6:15:31 PM(UTC)
paulr44
#3 Posted : Tuesday, October 14, 2008 3:10:04 PM(UTC)
Most likely the problem is a bad control board aka clock. This part has been discontinued by the manufacturer but you can try to rebuilt it through Replace your no longer available appliance control board with a remanufactured control board. PCBR repairs your faulty control board
Here are the break down diagrams for the Maytag range Model CWE9000ACE
