charmart1
#1 Posted : Monday, October 13, 2008 11:54:17 AM(UTC)
charmart1
I need to replace my dryer belt, I'm having problems trying to get inside,how do I go about removing which panel, step by step and replacing the belt? I have a 27" Whirlpool electric dryer. Thanks for any help
libertyappl
#2 Posted : Monday, October 13, 2008 12:18:36 PM(UTC)
libertyappl
Please post your model number.
Nat
Drags1998
#3 Posted : Monday, October 13, 2008 3:07:20 PM(UTC)
Drags1998
Remove the 2 screws under the lint filter, Put your Rt.Knee to the front of the dryer, with your left hand pull foward on the left side of the console down near the top of the dryer, and lift the left front of the top. Repeat for right side. Lift the top past 90degrees and lean it on a wall. disconnect wiring to the door switch, remove 2 screws from inside dryer going into the front panel,Lift slightly and remove from CLIPS at lower corners of thr front of the dryer, Install belt and put it all back together!!!:)
