AppliancePartsPros.com
Appliance Repair Help
Washer Repair
"Water won't come out of the hose from the washer
"Hi i have a old lady kenmore washer i had it about 11yrs, now, but it was given to me and i don't know how long my Godmother had it since she passed, i was smelling a burning coming from the back of the washer, and the water will not come from the hose now. it will spin, but no water will come out, can you please give an Answer to this Promble "Thanks
Is is not draining the water out after a wash cycle? Check your belts & the pump. Nat
"Thanks do i still have to buy a belt if the washer spin wash and the water can fill, but the water will just not come out when spining,
The belt is what controls the spin & drain on your washer. If the belt is worn or stretched you will need a new one. Nat
"Thanks you are Right! I Thought because the washer still wash spin and fill with water, it might not be the belt, but the pump because the water won't come out when spining' Thanks again for giving me a more Insight on this Promble:
Washer Repair
