AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer runs only while push-to-start button is depressed
My Estate dryer runs while the push-to-start button is depressed, but as soon as I let go, it stops. The drum spins, and it gets heat. Before this it was working fine, albeit with a squeaky belt.
Any hints would be greatly appreciated!
THIS FORUM IS DEAD!!!!!!! |
Thanks, Denman. That makes a lot of sense. I appreciate your help.
One question: I don't see the centrifugal switch on the parts diagrams. Is it an integrated part of the motor, or have I simply not seen something in the diagrams?
Thanks again!
Yes it is an integral [part of the motor. If you click in the picture of the motor in the parts (Item 62 in Section 2) a new page will open with more views of the part. You can then click on them to get expanded views. |
I see the pictures you refer to -- they are not labeled schematics, but rather several views of the part, correct? Would I be correct that you are suggesting I might look at the motor and see if I can locate and assess the health of the centrifugal switch, and see if I can fix it. If I am able to see that it is not working and not repairable, I assume my option is to replace the motor. Is that the approach you are suggesting?
Thanks again for your help!
I felt that a picture was worth a thousand words so suggested you look at the pictures.
There are 2 centrifugal switches, one for the motor and a second one for the heating coil. Since you are getting heat that tells you that the switches are being closed when the motor gets close to operating speed (not a mechanical problem). Therefore it is a bad motor switch and the only way to repair this is to replace the motor.
I did have a unit recently where the problem was just a loose connector to the switch so I would check the wiring first. |
Denman -
Thanks so much. Excellent and clear directions. I'll take a look at the motor tonight and see if I'm fortunate enough to have a loose wire. If not, I'll order the part.
Many, many thanks!
Denman (and others)-
I am finally getting to this this weekend. I've removed the back and opened the top, and taken out the blower duct. What is the best way to get at the motor? Do I get it from the bottom of the unit, or from the back?
I'd appreciate any guidance.
Bests,
Rob
I never got an e-mail notice telling me that you'd replied to my question about getting the motor out, so I'm just seeing it now. It looks like I'll have work to do this weekend . . .
Bests,
Rob
Dryer Repair
