racefann3
#1 Posted : Saturday, October 2, 2010 9:37:01 AM(UTC)
racefann3
The heating element does not shut off when the door is open. However, the element will stop heating if I manually turn the timer to the off position.
I checked the door switch and it checked ok. I suspect the switch down on the motor which has six terminal on it is faulty. Can someone confirm if this switch will cause this issue. Thanks for your help.
#2 Posted : Saturday, October 2, 2010 10:24:28 AM(UTC)
[COLOR="Blue"]I suspect the switch down on the motor which has six terminal on it is faulty. Can someone confirm if this switch will cause this issue.[/COLOR]
Yes that would also be my diagnosis.
The switch should kill power to the heater whenever the motor is not running.
Probably it's contacts are welded together.
Guest (6)
