1. will a broken idler pulley spring cause the drum not to spin up to speed? 2. if so how hard is it to replace? I have pulled the front cover and the belt tensioner just flops back and forth. Will the new spring fix the problem? I do have some mechanical background. What is the best way to replace this? thanks
if there is no tension on the belt it wont tumble the sping is easy there are two holes each end of the spring hooks into its sometimes easier from access panel in lower left corner from rear to secure spring
