Washer is less than 3 years and I have no warranty so here we go it used to sometimes make very loud clunk noise when spinning and now it will spin once in a while I have checked for the lid lever I don't have one and I can hear the lid clicking, but when I put it on spin I hear the hum of the spin but no spin takes place. If I have it set to spin open the lid begin the spin manually close the lid super fast it will spin out BUT not on a high speed. Leaves clothes quite wet.... for sure, from what I have read .... thinking it is the clutch any advice .... Help!
Sounds very much like a clutch problem. Take a look at Richappy's Sticky at the top of this page on Direct Driver Washer Brakes and this site on how to replace the clutch. The noise may indicate a problem with the brakes as well as the clutch. Clutch Replacement on Whirlpool and Kenmore Washers
Thank you so much for your time! I have ordered my parts and hopefully this will be the fix much cheaper than buying a new one after only alittle over 2 1/2 yrs. Will let you know if it's the fix. Thanks again for your time. :) Originally Posted by: sidfink43 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Sounds very much like a clutch problem. Take a look at Richappy's Sticky at the top of this page on Direct Driver Washer Brakes and this site on how to replace the clutch. The noise may indicate a problem with the brakes as well as the clutch. Clutch Replacement on Whirlpool and Kenmore Washers
