Ice maker gets no water even though I can hear water come on from time to time. I found wet ceiling in basement under the fridge, so shut off water supply now all is dry. My question is can something called celonoid ( may be wrong spelling) be changed and fix the leak ? Or do I need to replace whole Icemaker . Can any brand of icemaker kit work with Sub Zero? Thanks for any help
Originally Posted by: shatya  Ice maker gets no water even though I can hear water come on from time to time. I found wet ceiling in basement under the fridge, so shut off water supply now all is dry. My question is can something called celonoid ( may be wrong spelling) be changed and fix the leak ? Or do I need to replace whole Icemaker . Can any brand of icemaker kit work with Sub Zero? Thanks for any help subzero icemaker getting no water . water leaks in back of fridge only when filling sound comes on.
Sounds like the tubing came off and leaking on the floor instead of filling icemaker
