need help! about 6 weeks ago noticed ice dispenser would only give crushed ice,even in cube position.then last week no dispensing of any kind(water or ice)also light in door inop.I tested the freezer door switch-ok,possibly circuit board? or common wire between all three features? but why would ice only crush before failure? Thanks! Bill
Ok,thanks in advance to anyone that answers me,but I already found my problem,3 broken wires by the freezer hinge!! ooops! they probably broke at different times causing different problems along the way! I hope anyone reading this will use it to help themselves in diagnosis also.
