burner will not always light, igniter does work. If I light with a match burner will light with no problem. clean burner no help
If you can hear and see the igniter "attempting" then replace the igniter, they can get cracks in the ceramic coating and ground out to path of least resistence, be very sure the burner itself is free of debris and has all the air to fuel channels clear
