Heard noise investigated and found control panel flashing every thing and the ice dispensor door flapping in unison with the control panel
Originally Posted by: Rayken  Heard noise investigated and found control panel flashing every thing and the ice dispensor door flapping in unison with the control panel Rayken, You need to replace the main control board. It's located on the back of the cabinet, right side, middle heigth, looking from the front. Part number: AP4014490
You'll be fine once you replace the part and program it to match the machine. Good Luck, :cool: :cool: :cool:
Originally Posted by: Joe / APP Team  Rayken, You need to replace the main control board. It's located on the back of the cabinet, right side, middle heigth, looking from the front. Part number: AP4014490
You'll be fine once you replace the part and program it to match the machine. Good Luck, :cool: :cool: :cool: Thanks for the help!
Originally Posted by: Rayken  Thanks for the help! Rayken, You're welcome, Glad we could help. :) :) :)
I replaced the HV Control, went through the programing sequence and the code in the refridgerator will not take. I get a beep after I enter the code which is 0302.
Need Help please.
Originally Posted by: harsh  I replaced the HV Control, went through the programing sequence and the code in the refridgerator will not take. I get a beep after I enter the code which is 0302.
Need Help please. Your instruction sheet doesn't say anything BUT, The time to run the programming mode is limited, approximately 5 to 8 seconds, if you stall too long between selections the board locks itself and wont accept the new code. You may want to unplug the door hinge connector or the power cord between attempts. Something else to check , is the serial number(first two numbers) make sure we orderred the correct part for the series number of your unit. :confused: :confused: :confused:
