purchased a new overload switch, relay switch, capacitor and cover female end is too small for switch in relay do i need to purchase all the wiring for this to be connected
:confused: Originally Posted by: greene149  purchased a new overload switch, relay switch, capacitor and cover female end is too small for switch in relay do i need to purchase all the wiring for this to be connected
If you are talking about the push in wire terminal, then you can replace it with a larger size.
