prkarls
#1 Posted : Wednesday, September 29, 2010 5:47:28 AM(UTC)
prkarls
Hello,
I'm looking for some help debugging my Kenmore 106.56662500 fridge ice maker. It has stopped producing ice.
Here is what I have done so far:
I have tested the ice maker water value. -working
I have checked the ice maker water tubing for clogging. - no clogs
I tested the thermal fuse on the ice maker. - It was broken but I bypassed it to make sure that it was the only problem. Still no ice.
I know the emitter board is working properly and i'm 99% sure the receiver board is working properly.
I checked the AC motor in the ice maker to make sure 120Vac would still spin it. - It does
The LED output code indicates the ice maker is sensing/working properly, it just won't begin a harvest. The "claws" of the ice maker are currently pointing straight down(the same position as when I reinstalled the icemaker).
I only have two ideas at the moment:
1. The ice maker valve is no receiving the signal to turn on and fill the ice maker.
2. The ice maker is shot. This would be OK with me, I just want to make sure before I buy it.
Does anyone have any input on this? Any help is greatly appreciated.
One last thing. Is there a way to bypass the ice maker and turn the water valve so I can rule out the valve wiring?
Thanks,
PK
Joe / APP Team
#2 Posted : Wednesday, September 29, 2010 6:49:04 AM(UTC)
Joe / APP Team
Originally Posted by: prkarls Go to Quoted Post
Hello,
Thanks,
PK
PK,
Great report,
I'm pretty sure , you have a bad icemaker assembly, and most likely in the mold heater assembly.
Part number: AP3182733
Since you have voltage to the I/M control module, you should be able to insert your jumper wire in the L and V contact openings and actuate the fill valve from there.
Good Luck,
:cool: :cool: :cool:
CAMPBELLGC
#3 Posted : Sunday, October 31, 2010 8:35:14 AM(UTC)
CAMPBELLGC
PK Did you ever find the location of T and H meas. holes on your Kenmore icemaker?....I have the same model as you and I can not find T and H along with L and V meas . contacts...I have basically all the same problems as you...George Campbell...Stuart,FL
