Please Help! My Ice Maker stopped working (modular for side by side with an ice bin) and I checked to make sure the water line is clear and tried to jump the T-H poles with nothing happening. I ordered a new icemaker which has been installed for 24 hours and it is still not working. I tried jumping the T-H poles on the new maker and still hear no noises (I did hold the door lever switches closed). I am wondering if it is the water soleniod, but I am bothered that the ice maker will not start a harvest cycle when I try to jump it across the T-H terminals. Any thoughts would be appreciated.
ShaneH
If you are handy with a meter, go to web site www.applianceaid.com/icemaker-modulual.html You may have wiring problems in the fridg. Check for 115 volts to the icemaker, or you may have a blown thermal fuse if you kept the original cable.
