Does not make ice until someone jimmies with it. I believe the problem is with the Ice stripper. Can anyone tell me how to remove it so I can replace it.
look under icemaker in the right side rear you will see a 1/4 in hex screw remove that then the plastic cover it was screwed to then pull icemaker towards you in slides out of a channel then unplug it
