2 Pages<12
gravelkm
#11 Posted : Tuesday, March 12, 2013 4:12:11 PM(UTC)
gravelkm
Originally Posted by: Opie432 Go to Quoted Post
I had the same issue but took a diffrent approach. I removed the shaft and replaced it upside down. This way, the shaft end that stripped out is now in the motor housing and you no longer have a stripped shaft in the auger. To ensure the stripping didn't happen again, I wrapped one layer of electrical tape on the top end of the shaft and all workes just great!! Give it a shot, no cost to you!!
How did you remove the shaft? Is it something you can take off with regular pliers? Should I use vise grip pliers to hold the "base" part of the shaft?
Guest (7)
2 Pages<12
