I have a 23 year old Kichen Aid whisper quiet dishwasher, model KUDS21SS0, that started leaking at the bottom of the door - right side. In reading your posts, the leaking may be coming from a few areas. I have a service tech coming out tomorrow. Based on the dishwasher's age, I want to be prepared in case the dishwasher is not worth fixing and/or the needed part has been discontinued.
At this time, I would like the know the current dimensions of my dishwasher. I cannot find the owner's manual, but located one on Whirlpool's site. Unfortunately, the dishwasher's dimensions are not given in the manual or available online. I called Kitchen Aid's customer service department and they don't know the exact dimensions. Since my machine is quite old, detailed informations is not readily available. The Kitchen Aid rep was told by a supervisor that machine's height and width would be practically the same, but the depth may increase by 1/2 to 1 inch.
Does anybody know the exact dimensions of my whisper quiet dishwasher? Would a new Kitchen Aid machine be deeper than my current one? Your assistance would be greatly appreciated!
Thanks!
Hiosilv4
Here is the install sheet for your unit. Page 4 gives the minimum cabinet dimensions which will be the units size. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Here is the install sheet for your unit. Page 4 gives the minimum cabinet dimensions which will be the units size. Thanks for quick reply and information! :) Where do I find install sheet you are referring to?
