Oven control panel is beeping, no error code. When powered off and back on, clock works and can be set. After a couple of minutes it starts beeping again. No error code and no buttons work. Only off/clear and start can be pressed to make a beep sound but nothing else works. Any help would be great.
Unplug the range and try to clean the touch glass with a glass cleaner. Do not spray the cleaner on the glass, spray it on a towel.
If it would not help, disassemble the control panel and clean the ribbon cable with an alcohol.
I will try that first-was going to replace the oven control computer.
