[FONT="]I purchased part# 241872512 - Refrigerator door gasket and wondered how I would go about removing the old gasket and replacing the new gasket? Thank you[/FONT]
Originally Posted by: brianwbates  [FONT="]I purchased part# 241872512 - Refrigerator door gasket and wondered how I would go about removing the old gasket and replacing the new gasket? Thank you[/FONT] Brian, Based on what I have here, Your door is a "one piece"part. Your door gasket is a "slip on / force fit" part. Basically: Removal Grasp the gasket in the center, between two corners, and pull up or away from the liner, corners will be difficult, but do able. to remove gasket from liner assembly. Reccomendation You may find the replacement procedure a bit easier if you warm the new gasket in hot water or with a hair dryer. Inatallation Start installation in a corner and work gasket onto liner in both directions, all the way around the liner. Keep the hair dryer handy for the corners, they can be difficult. Good Luck, :) :) :)
