:( I need to convert a propane gas dryer back to natural gas. There is a sticker in side the door that states : convert to LP 11' manifiold.lpressure reg immobiliezied to full open position with a blocked open plug. How would I go about change it to natural gas. Plesase need complete instructions . Thank you
You need to replace the propane orifice with the original natural gas one. If you don't have it you can get it from Sears 1-800-4myhome. It probably looks like a small brass hex head screw with a small hole in it attached to the burner.
