WW3609
#1 Posted : Saturday, September 25, 2010 9:19:17 AM(UTC)
WW3609
The regular side of frig is very warm and foods are beginning to spoil. The freezer side is cool enough to the point that I've moved all liquid items - juices and mild over to it. It keeps them cool, but does not freeze them. There's ice buildup on walls. Has stopped making ice in the ice-maker.
Note: it was doing the same thing about two weeks ago. I unplugged it overnight and did thorough cleanup. When re connected, everything worked just fine as they should. But then this week, it's gone back to the same problems. And with money issues as they are right now, trying to decide if this is an easy fix, or would I need to have to buy a new one, something I'm really not looking forward to?
Help! and thanks....
dgdl441
#2 Posted : Sunday, September 26, 2010 4:06:46 AM(UTC)
dgdl441
thanks for coming our site: nike,nike shoes,jordan shoes-www.nikeok.com , best quality and customer service here!be pleased to inform you,we just updated our site products online, and now you can place order and get a good deal with discount price online, below some changes for your informations;1. all items with reasonable prices, and easy to order.2, if you order over 120usd, all items will be free shipping.3, for above 200usd order, we hv a special gifts for every packages.our shipping service as following;a. payment: Paypal/western union/money gramb. shipping way: EMS,USPS,DHLc. shipping time: about 3-5daysd. deliver model: door deliveryyou can place order online, we will get your order details when you finish order online,thanks for your time!all the bestqingcustomer service rep.nike,nike shoes,jordan shoes-www.nikeok.com
#3 Posted : Monday, September 27, 2010 3:03:18 AM(UTC)
Replacement parts for General Electric TFX22ZPDAWW Refrigerator | AppliancePartsPros.com
Sounds like you may have a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 257 in Section 4) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 230 in Section 3) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 240 in Section 3) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
