woodenrose
#1 Posted : Monday, October 6, 2008 9:54:04 AM(UTC)
woodenrose
We just purchased this washer in an RV - it is very small which is required for our situation - I can't find a replacement so I would like to get this one fixed. So far we have tested fill, drain, agitate, etc. They all work - it just won't spin. We have also found that all 4 straps that hold the tub centered and up are broken. Would they be the problem or is it likely something more complicated? We would appreciate any help you can offer.:(
libertyappl
#2 Posted : Monday, October 6, 2008 10:17:31 AM(UTC)
libertyappl
For starters you will need part#AP2915970 (4 of them), you will need to check your motor, pulley, transmission and brake assembly(could be stuck) to make sure they are engagine during spin.
Nat
