AppliancePartsPros.com
Appliance Repair Help
Washer Repair
maytag wont spin after installing a Mounting stem repair kit
i just installed a Mounting stem repair kit in my washer because it was leaking out the bottom of the tub. i put it all back together and now it wont spin....it will agitate though
what did i do wrong
dave
The spin basket is probably hitting the upper tub cover. Also, you must replace the sleeve bearing when replacing the seal!
Washer Repair
