There is a light on the front of our stove that is flashing "locked door" and the oven door is open. We did not try to lock it. Now the door will not shut entirely.
HELP!
The door lock is stuck closed. Which is why you can not shut the door all the way.The is a tag with the model number located on the range frame, usually in the storage drawer or oven compartment. Nat
