#1 Posted : Thursday, September 23, 2010 11:07:58 AM(UTC)
When I open the fridg door, the power relay in the back control pc board W10135090 starts chattering. Fridg works normally except the control panel lights fail to work, but the door switch is ok. If I remove the switch entirely, it still chatters. Hope someone has seen this before.
jsarg419
#2 Posted : Friday, September 24, 2010 10:02:25 AM(UTC)
jsarg419
I am having the same problem took the door switch off and it tests ok. Today the chattering stopped but the problems still there. I have replaced a relay in the mainboard but no change.
#3 Posted : Friday, September 24, 2010 12:41:17 PM(UTC)
I am going to replace the control board. I tried spraying the board with non-residue cleaner but no change. I suspect it might be a wiring problem but failed to see any connector problems. Replacing relays usually will not fix this type of problem.
Will inform you if the new control board fixed the problem. As a side issue, the adaptive defrost counts the door closings, and with a lot of closings like that, it will probably defrost more frequently.
jsarg419
#4 Posted : Friday, September 24, 2010 2:17:16 PM(UTC)
jsarg419
I have fixed mine on the back of the board the circuit line from the middle prong on the relay to its connection was burnt. I soldered a wire from each terminal using the solder on the connections worked like a charm.I will be getting a surge protector today. I got this fix off of fixya.com pyro44922 has some great pics.
#5 Posted : Friday, September 24, 2010 3:26:36 PM(UTC)
Thanks so much jsarg419, that fused open ribbon is hard to see, did not order the board, will fix the one I have.
