IreneandLarry@q.com
#1 Posted : Thursday, September 23, 2010 7:46:35 AM(UTC)
IreneandLarry@q.com
How do I remove the outside :confused: cover of the ice/water dispenser to install the ice door kit?
Joe / APP Team
#2 Posted : Thursday, September 23, 2010 9:07:03 AM(UTC)
Joe / APP Team
Irene,
Which door flapper repair kit do you have ?
I hope you have this kit, just in case.
Part number: AP3872692
First thing to do is, unplug the power cord or shut the power off to the refrigerator
To access the door flapper :
Remove the drip grill from the dispenser.
Along the bottom edge of the dispenser panel you'll find two slots.
Use the grill as a pad or pivot point, and with a large flat bladed screw driver pry out on the slots so the panel pops out and carefully push down on the panel.
Diconnect the wire harness from the switch assembly and set the panel aside,out of the way.
Remove the two screws holding the other switch assembly to the dispenser body,
You should now have access to the flapper door and paddle assembly.
The rest is self explanatory.
Reverse the process and test the flapper/ ice dispenser.
Good Luck,
